Hi All,
Thanks for the replies, and sorry that I havn’t got back sooner. I have been a bit busy with work repairing sailing dinghies.
Herman, very interested in the boat that you built, but no I don’t have a B14- though I did quite a bit of work on the B14 that my boss used at the worlds
My interest really is related to surfboard/windsurf board applications. I was trying to figure out how easy it would actually be to build something. Although I havn’t actually built anything yet, but well, I am guessing that the processes would be similar, just different materials?
I found that you can shape out of something called bio-foam. This is a foam which is derived from Sugar. It still requires fossel fuel in the processing in order to produce it, but I think the point is that it creates a lot less CO2 Emitions. See their website.
I also found a bio-epoxy. Not really sure if its any good, and how its characteristics compare with say, Ampreg 21 or the high temp resins. But it looked potentially quite promising. This is their website.
I figured that for a core, the best use would be end grain balsa wood - or would another type of wood be preferable? - I don’t know an awful lot about wood - but I am learning. I am not 100% sure how you would wrap an object (like a foam shaped), guessing though, that it would involve a vacuum bag. Its pretty common in the windsurf world anyway, for boards bottoms/hulls to be wood these days - as they seem to last longer (re-enforced with carbon usually). Running stringers through the foam is also a pretty common way of re-enforcing things. I even know of companies putting wood into the rails as well.
The part I am not 100% sure about is the re-enforcement. Does anyone know any articles/websites/any ideas what I could use. I am guessing that you can get the fibres weaved in the same ways as glass or carbon - IE, uni, woven and bi-axel? What are the the stiffness/strength ratios like compared to say standard modulus carbon or E glass?
Anyhow, just trying to get my head around it all at the moment. As you guys have all said. Its a bit expensive at the moment - probaly because no-one is really manufacturing much in it, and its not being produced in great quantities, so their are no economies of scale there.
Quite interested in that workshop in London. I may try and attend it, however works very busy at the moment.
Thanks again for the posts guys,
Mark.
