Well I would be wrapping it in twill for looks afterwards.
I might be waaaaaay wrong on this idea but I figured that you would be able to do it if you cut many sheets of cloth and layered them one on top of the other in different directions. compress manualy and squeeze the excess resin out of it. Let it kick and then remove it and heat cure it.
I would be machining these into “triple clamps” for motorcycles. The would have a "pinch cut in them for clamping the forks and I would devise a way to affix the steering stem.
If you can do it with crappy aluminum casting, why not carbon?
The reason I question so hard is that when I worked for the factory superbike teams I use alot of carbon fiber brake pads. They look from appearance to be just like chopped strand matt in looking at them. But they were SOLID as hell and weighed nothing.
Granted they sucked with the technology about 10 years ago when we used them but we tried to make em work!
The new ones are way better and work for the top riders.
Oh and I would be using a manual mill with some type of cutter for plastics, lots of teeth and carefull cutting.
