best way to prevent print though on infusion?
what are some tips on to help reduce print through on infusion layups?
how long is the gelcoat dried for?
I get print though about 3 days later
so no techniques or tips ?
I’ve never tried this, but a layer of thin fiberglass that wets out clear (4 oz or less per yard cloth with a very fine weave) can reduce or eliminate the print through. I’ve read this from a couple of sources in boatbuilding & modeling forums, but take it for what it’s worth because I’ve never seen the results.
i have some stuff for fiberglass stuff for print through, can I just make my gel coat thicker?
Yes or use surfacing veil…
What is this print through you speak of?
I believe it is where the weave/texture “prints” through to the top layer, so instead of having a smooth surface, the surface shows the texture of the carbon weave.
