Hi,
I would like your opinion on the best way to make a catamaran dagger board. The profile is an airfoil. It will be a copy of the one in the picture. The original is made in 2 halves. Each halves has the skin laminated then high density foam is poured in the halves. they cut the excess foam to create a flat surface and the 2 foam faces are glued together.
I could use the same method but would like to make it one piece and empty to reduce weight. Some ribs will probably be necessary inside. I would like to use carbon fiber.
