Hi
I use 2k imc everyday , but my objective is to get gloss Finnish. BUT I use flouro paints , SEM from colour horizons. These Are concentrates that you mix with clear.
If painted just like that you get a dull Finnish , so I clear in mould first , then flouro , then back it up with white and then undercoat so the laminate stick to it.
Although that doesn’t directly help you , I think the process does. My moulds are shinny and with out clear it a little dull/Matt type Finnish.
So I’m sure a Matt black paint , backed up with undercoat would do the job fine.
Only one way to find out
Maybe try a test on a piece of window glass first to see it it works and from a shinny surface it give you the desired result.
Tim
