Best Clear Coat
Trying to find a another clear coat that has UV protection, I mostly overliad/wrap items in carbon fiber, I currently use Dupot Automotive w/UV protection. is there anything else that good to use that not to costly. Beside Dupot Premire and House of Kolors.
to tell the truth I use the cheapest of the cheap clear coat when I overlay stuff. It takes a little longer to dry but never had a problem with it in any way shape or form.
Let me make question clear, I mean as far as clear coat in spray can, I have to order from BASF for aero-max 100 and just want to make sure it dones’t turn yellow after being in the sun. So I can use any cheap clear coat and will not turn yellow.
I use products from Transtar for clear coat. They are real durable and hold up well to full sunlight. I cannot specifically recall, but I think this is the one - http://www.tat-co.com/datasheets/6771.pdf
I do alot of smaller items, is there any good clear coats in a spray can form that has UV protection.
Not really. Good durability and good uv will be hard to get from a 1k (single component) clear. I mean, you’re stuck with either enamel or laquer. You might be able to use a good laquer clear from say, duplicolor, but I would stay consistent and use the same clear for everything (plus you can use a much higher solids clear if you’re using a gun), not only that but it’ll be cheaper in the long run.
I would buy a touchup or “door jamb” gun. Or even an airbrush if the parts are really small so you can use a catalyzed urethane clear for everything.
