I bought some West Systems 105 Resin with the 207 Hardner.
http://www.westsystem.com/webpages/epoxyworks/18/product_207804.html
The objective is to mix this 105/207 resin for the outside surface coat for the ski board I’m making. The idea is to help give the board some UV protection with the 207 resin.
So far, I have not worried at all on getting a nice finish on my parts…I’ve just pulled them from the mold and started trimming. So the finished board will be the first surface coating I do and I’d like to make sure it doesn’t look really nasty.
After mixing this resin, do I just simply brush a thin layer onto the board? Will I need to worry about runs or brush lines? Does it level itself out pretty good? I doubt you can spray it…
The only other surface coating I’ve done is to spray Duratec Primer on a plug and brush on the Fibreglast surface coat to build my molds.
Thanks.
