Hello,
Thanks for stopping by. I recently laid up my first infused part and found that with 6 layers of 199 gsm cf, my part is still not to the stiffness that I would like. I figure the best way to get the stiffness that I want would be to use a core material. I chose to get some 1/4 balsa core since my part will not be anywhere near water and its pricing is reasonable. I would like to infuse this part, but I am concerned that the pattern on the balsa may print through the outside layer. I plan to use 3 layers of 199 gsm for the outside layer and 2 on the inside. Now if it wont print through and 3 layers is ok to use, what would my layup be like?
3 layers cf
1/4 balsa core
2 layers cf
peel ply
perforated release film
flow media
Or would it be best to infuse the outer layer then infuse it again with the core and the inside layer?
Thank you so much for the help. I wouldn’t even been able to get this far with out this forum.
