I have been making small diameter (1" and 2" square) tubes using a wet layup procedure on aluminium mandrels, waxed, and then coated with Rexco Coverall PVA. I am using a 200gsm twill with wide tows. I am using Aeropoxy PR2032 with PH3665 hardener. Being made on male mandrels, the surface has a texture, but the tubes are mainly used in a utility setting, and I am generally satisfied with the quality. Here’s the big problem.
When the tubes are taken off the mandrel, the surface is nice and black, as it should be. I washed the tubes in order to get the release film off of the inside, and the outer surface has turned a milky white. It is entirely unacceptable cosmetically. It looks something like soap scum. I have tried everything to remedy it, including washing with more water, scrubbing, steel wool, acetone etc. I have also tried heat, from a little to melting, and nothing works. The only remedy that works is sanding and rubbing down with a thin layer of black adhesive.
It is obvious that it is a result of washing the tubes, and thus it must have something to do with the release compound. I was presoaking the tubes for about 5 minutes in a tube of PVC, so my conjecture is that the PVA was dissolving and thus dispersing into the bath. But why would a diluted bath of PVA so drastically change the surface? Any insight or ideas for other solutions would be greatly appreciated.
