Hi Guys,
So, I am putting together a small vac pump system for bagging smaller items.
First trial run yesterday and things are OKish. Had a leak in the bag which sealed itself after 5-6 hours (I guess it happens), but until then I had to manual switch on the pump every 15-20mins.
So, now I know next, imminent, upgrade is an SMC pressure switch (ZSE30 series).
But my question is, can I get by with just using a non-return check valve instead of a solenoid valve? I thought solenoid was a must-have but then saw mentioned here, that it seems people get by without? That would be nice to keep things simpler for now.
Would that be OK?
Yeah, I need an SSR relay and 24V power too.
Pump is a small AC evacuation pump. Works nicely so far (tested in the shop and it pulled substantially higher vac than its bigger brothers).
