After doing quite a bit of research I have come to the conclusion that I am going to use an autoclave method for curing my prototypes.
I have found countless video demonstrations and articles detailing how to do RTM setups and curing methods, but I haven’t found many providing great detail on Autoclave methods.
First I have a few questions on the autoclaves used for curing composites:
Do they pressurize or create a vacuum? Are the moulds bagged when put into the autoclave? Are pre-pregs only used? or can I put a wet layup or an RTM into an autoclave to help achieve a higher CF to resin ratio?
The product I am trying to prototype will require a male and female mould. Do these have to be made from metal when using an autoclave?
I am trying to prototype a music instrument neck; guitar, violin, bass guitar, etc. I have many ideas on different approaches, but I am fairly certain in order to achieve the quality I desire, an autoclave will be necessary.
Accessibility to the autoclave isn’t a major issue as I work in an industry where access is available. I just need to get on the right track on getting my tooling created properly.
Any “I did this already and learned the hard way” type of tips would greatly be appreciated!
Thank you!
