I have a question :
What will happen if i cure -at the specified from the manufacturer
schedule temperature a prepreg material but instead of autoclave process i use just vacuum bagging process ?The laminate will around 2 mm in thickness . I think that the autoclave helps in less void content so the material has some ‘‘Small??’’ percentage of better properties.
Otherwise the resin matrix will cure as it was supossed to cure without any difference?
1)Am i right or not ?
2) Do you use prepreg for autoclave process in out of autoclave process ?
