i finally purchased a few things after talking with someone from Solarcomposites.
-3k 2X2 TW 270GSM, 640Ksi, Carbon Fiber
-AdTech 820 Resin & Hardener
Their recommendation was to add some kind of strips in both directions, to give the carbon fiber some curves/valleys which will make it stiffer compared to a flat piece. I was thinking of picking up either some balsa, basswood, or poplar wood strips which ever i can find locally and use those to create the valleys ect…
I attached a photo that someone else posted of a CF brace they made and added some dotted green lines just to show how i plan on placing the strips.
Although the photo is of the same chassis that i have, this person bent the two arms that stick out which is where the servo is mounted so that it is level with the part of the chassis where the engine is mounted (photo with the #2), I want to first try and make this brace with out bending those since I will need to make other changes up top to the brake and throttle linkage.
So what i am working with is shown in the top left image (photo with the #1) where those tabs (yellow arrow) are lower than the area where the engine mounts (red arrow)
one thing i am not sure about is how thick those strips should be, i found square strips online as small as 3/32" not sure if that is big enough to see a benefit but i think it will be hard to fit strips that are much bigger than that.
So my plan was to first cover that area in painters tape and add 1 or 2 layers of fiberglass, because i read that the CF can corrode the aluminum if it has direct contact with it. Next i would make the cutouts that i need on the fiberglass and mark or maybe even drill the holes that i need. Followed by gluing the wood strips as shown in the attached photo and add the CF on top of that.
Any input, suggestions, things to look out for would be appreciated
Thanks again
