I’ve been using foam brushes to apply epoxy surface coat. The brush seems to get “limp” after a short time. They almost fall off the wooden handle and not really controllable. What do you guys use and are there higher quality foam brushes? Thanks in advance.
The Highest Quality Foam Brush…hehehehehe !!!
We just buy those cheap brushes and cut 2/3rds of it off so you are left with a much shorter bristle area, it keeps the bristle stiff for application and reduces any fine hairs of the brush from escaping.
Curious to hear what others use as well…
