this looks like another semi-perm type. Price is $90 bones a gallon. Forever in search of the perfect release.
https://www.airtechonline.com/htm/defaultIE.htm
General Information
Safelease® 30 is a water based P.T.F.E. release agent that contains no silicones or silanes. Safelease® 30 can be used for cure cycles up to 450°F (232°C). Safelease® 30 can be used on composite and metal tools and provides a superior release from epoxies, phenolics, BMI’s and urethane resin systems. Safelease® 30 does not attract moisture so steam does not develop on the mold surface during cures. Safelease® 30 is the only water based release agent that works on composite molds without needing a sealer. One coat allows multiple releases. Safelease® 30 is an air dry system. Heat cure is not necessary.
Application Instructions
Note: Shake well prior to application.
Thoroughly clean and dry mold surface.
Apply one light coat with a lint free cloth or with conventional spray paint equipment.
Adjust the spray nozzle and air pressure to produce a light mist.
Allow approximately 30 minutes drying time at room temperature.
Apply a light buff with a lint free cloth to remove any excess.
Mold is now ready for production.
Cycles
Safelease® 30 is capable of multiple release cycles with most resin systems.
