I have been doing some flat panels recently using poly spray gelcoat and poly/vinylester infusion resin. Normal carbon twill layup etc, b stage gelcoat then infuses fine no probs.
Even if I postcure the panels, the gelcoat on the cut edge after I machine them just kinda flakes away. You can get your nail and pick it off. It should bond together super well but I cant send stuff out like this!!!
Previously I have mostly been using duratec high gloss clear surface coat/epoxy resin on panels, no problems at all when it gets cnc machined… The only thing is epoxy takes forever to fully cure literally a few weeks when its colder.
Has anyone experienced anything like this before??
Its pretty cold here at the moment but I try to keep the shop warm so I cant see that as a problem.
