I’ve been having issues with my wax releases. I’m making flat panels off of glass. First laying down the metalflake clear gelcoat then my laminates. At first I was using TR104 Hi temp wax release. This wax was very easy to apply and wipe off, a breeze to release the panels but then I would have fisheye problems when laying down the gelcoat.
A couple forum members suggested to use TR108 basic wax release since it’s compatible with the use of PVA and will solve the fisheye problems. I tried it out and yes it did solve the problem. No fisheyes! But saying the TR108 is a PITA to apply is a major understatement. Instructions state to wipe on and wipe off immediately which I do. The wax leaves streaks and residue and is very difficult to wipe off completely even though I wipe it off immediately after application (before it dries). The surface is also not smooth when i glide my fingers across the glass as the TR104 was causing the panels to be much more difficult to release after cure. The only way to get off the streaks and residue is to use EXTREMELY hard pressure or use was stripper compound and a powered buffer but that strips the wax layer and I’m back to square one…
There has to be something better than this!! I have only used TR104 and TR108 waxes. Is there any other brand of wax that is compatable with a gelcoat and easy to apply? Rexco, Partall, Meguiars, world’s finest?..
It’s going to heat up here and I don’t look forward to long, tiring hand buffing applying wax in 95 degree heat and taking 30 minutes to lay down one layer… Any suggestions?
