Hi everyone,
Sorry if this has already been answered, but I tried searching for it and read loads of posts on flanges but couldn’t find a definitive answer.
What is the best material to use for my flanges when the flange needs to sharply change direction by twisting 90 degrees? I need something that can be bent to this extent easily but is also strong enough to hold the weight of the gel coat. Iv tried plasticine however it keeps falling off the part when it is moved or collapsing under its own weight. Iv read that aluminium and certain woods are good to use however i think they wont be flexible enough.
And also i read somewhere that people fill the void between the flange and the part used for the mould, i was thinking, wouldn’t leaving this void be a good idea as when the part is finished it will give me an indication of where to sand back to?
