so before getting started (I have to wait till summer anyways) I have yet another question. i’m gonna try to explain this as best I can without a pic. So the center of the object has a rectangular area that is inset around 3 inches, with dimensions of say 10" by 5" and the whole object is around 15" by 10" and 8" tall. when you attempt to infuse or bag the object, will the weave distort on the areas at the bottom of the inset part or in the corners? I figured it might since certain areas will be getting pulled as the vacuum is applied.
Hope I explained myself well enough, otherwise I will draw up a picture.
Evan
