So my new process of making high quality full carbon parts, (for strength and appeal) requires me to put the fabric into the mold with out coating the mold with a clear top first.
I’ve been waxing, then just wiping PVA with a microfiber towel and then putting the fabric in with super77. It works pretty well, but sometimes I get vinyl ester residue stuck onto the mold.
I’d like to coat all the molds nicely with PVA and then lay the carbon fiber in, but since I need the super77 to keep the fabric down. When I go to press the fabric into the corners or when the fabric shifts very slightly it tears the PVA. When I go to infuse resin leaks through those tears and traps the PVA into the part, and or fills the corners of the molds with resin I then have to really work to pluck out.
Is there a way around this? If I spray several mist coats and then a flow coat of PVA do you think that will help? I’m using reXco Partal coverall film. The purple stuff. I’ve used the Partal green as well. Is there a PVA that is stronger as far as tearing goes?
