I’m building a wheel prototype that is similar to a mountain bike wheel. It will have 6 (round) tubular spokes.
I’m concerned about the strength and lateral stiffness of the wheel…more so than it’s overall weight.
If I built 2 wheels out the same size tubing (OD and ID)…one with aluminum spokes, and one with CF spokes…which would be the better choice in terms of lateral stiffness and strength? (The hub and rim assembly would essentially be the same for both.)
If I go with CF I would likely be using (0.075" OD) pultruded CF tubing from Dragonplate http://dragonplate.com/ecart/product.asp?pID=744
(Other recommendations are welcome.)
TIA,
Steve
