I am trying to get some aluminum molds done on a budget. Can someone with experience hand finishing aluminum molds suggest a maximum RA value I can get away with and still be able to block sand + polish to a fine finish? The surfaces are curvalinear so there is a mix of vertical and horizontal milling.
Also, I have read to include a proud edge at join lines to protect the corners during hand sanding. Should I plan for that to extend up from the parting line in addition to inwards? Suggestions on how big I should make it? (thinking about 1.5mm?)
