To qualify this post, I am not necessarily trying to avoid vacuum bagging, but rather I want to explore alternatives to achieve a similar result.
For this to be logical, the alternative process needs to be nearly as effective as vacuum bagging the wet layup, depending on the criteria. It should also hopefully provide a solution to the usual issues with vacuum bagging.
I welcome other ideas and theories, but allow me to start with my own: sand forming and sand compression.
Using a sand typically used in stone pavers, such as Sakrete, one could (theoretically) form a mold using the wet sand (which hardens when dry), spray in PVA or similar, lay in the fabric, lay a sheet of flexible plastic, then cover with more wet paver sand to achieve a compression molding effect.
Thoughts?
