I have been experiencing a few problems with a couple of my molds. No matter which type of release agent I use I keep damaging my molds in certain areas, this damage is never on the flat part of my mold but is on protrusions or on sharp radii areas. One mold has been remade about 6 times and the same problems occur. I have used the following release agents :
Meguiars M-08 Mirror Glaze
Meguiars M-08 Mirror Glaze + PVA
Easylease Semi Perm
Easylease Semi Perm + Meguiars + PVA
Easylease Semi Perm + PVA
Now I’m sure it’s not my mold making process that is at fault here because I have many molds that release perfectly with no damage at all. BTW I’m using Epoxy and glass for my molds.
I have been exploring if there are any other materials that I could use to make these molds, ideally I would like to use aluminium but the cost of having these made for me is too much. So I have been thinking about other plastics, namely ABS or Polyurethane. I have read that it is easy enough to make a liquid ABS by dissolving ABS shavings in acetone. I have also found a liquid Polyurethane resin. Do you think any of these two materials would be any good for making molds? Would they be tougher than epoxy? Or is there any other materials I could use?
