Good point about learning thru good and bad molds/plugs and parts.
I’ve been practicing making a mold for a light switch plate.  I had a couple errors i’ve learned from or think i have learned from.
#1  I did not make the flange area large enough.
#2  I didn’t build up the modeling clay in the switch hole enough.
#3  I didn’t smooth out and model the clay around the perimeter of the plug good enough.
Is using modeling clay for filling plug to flange gaps a bad idea if the outdoor temp is 100F plus?  I think the clay may have melted some with all the heat.  This really does suck because outside is the only place i have to work for now.
http://s210.photobucket.com/albums/bb186/Fastrr_photos/?action=view¤t=Switchplatemold1.jpg
http://s210.photobucket.com/albums/bb186/Fastrr_photos/?action=view¤t=Switchplatemold1b.jpg
I am now making a new plug and mold for two switch plates on one mold. This time I am using a small sheet of glass as the plug flange.   Any advice is muy appreciated
RC_51  I like what you’re doing, keep up the good efforts and keep posting the good and bad.  We all learn from it.
