i see airtech now do a starter kit including a pressure pot,$635,im sure you could do it a little cheaper but it would be nice to know that everything supplied is 100% the correct stuff and it is then just down to you to produce a decent result
im tempted.ive just emailed em to see how much it would be without the pressure pot.
stew i will pm you in a bit, flying visit
ok so this is a product value section…like the books or videos.
I bought the airtech reusable brush on vac bag kit…I fell it was way overpriced and didn’t use all the stuff in the kit.
The jury is still out on this one.
Dougie, how much did you pay for it and is it the clear silicone with the white netting kit?
I am not positive on the price, but $250 sticks in my mind.
Yes it has the white netting that can be bought at Joann fabrics. It also uses the same semi clear silicon caulk that comes in tubes from a hardware.
man does it stink.
the kit was big enough for 8 sq ft.
I was totally disappointed when I got it. I thought i paid 2 x too much for what i got. the fitting that was supplied was not necessary. We used it cause it was there. The channel stock that was supplied for the vacuum flow was nice. but I can’t use it directly on the face of the part.
I am just not happy.
