Hello again
this is a mold for an air intake pipe (air filter to turbo) for my glanza. The weird shape comes because it passes through some impossible places (oil filter, air con, beneath the powersteering and through the p.s. and air con belt, to get behind the headlight)
so i made this two piece mold. i will be making two halves out of 3 layers of 100grm fiberglass and black epoxy. then these halves will be trimmed, placed back on the molds, the two molds bolted together and some glass will be used to join them. after that, i will add two carbon fiber tubes over that tube, and wet it out. I wont use vacuum both because the tube will be crushed , and because it will leave nasty wrinkles on the outside.
more coming soon
