I too have trouble from time to time with air in my laminated parts.
I am making some parts using clear gel coat sprayed into the mold. I let it gel for 2 hours, then i lay down a completely dry layer of carbon fiber. I work that layer down with my hands and a cheap plastic grocery bag, so i don’t snag the weave. I get all the bridging out most times.
Next i brush in plenty of vinyl ester resin, then i use plastic squeegies to move the resin over and into the first layer of cf cloth. Next i lay down the second layer of carbon fiber and wet it out with resin after it is placed onto the mold. This second layer i just brush down lots of resin. I don’t let it pool in areas… i remove the excess pooled resin by hand. If i need a third layer of cf then i do the same as i did with the second layer.
Now i lay down nylon peel ply, then 10 oz breather cloth, 1 layer. Then i vacuum bag the whole thing. As the air escapes i work the bag and laminate into all the corners and recesses, making sure the vacuum bag pleats are located where needed.
I let the vacuum run for 4 to 12 hours depending on how soon i can turn it off. The resin only needs 4 hours under vacuum to cure past the gel state.
When i demold the laminate i notice air trapped in between the tows of carbon fiber and some air bubbles between the clear gel coat and the cf.
I do not use a vacuum “suction cup” thru the bag and on top of the laminate. Instead i insert the vacuum line into the bag and wrap the end of the line with breather… plenty of breather so no air is kept from moving. I line the underside of my envelope vacuum bag with breather so air can move thru the bag. I also use that layer of breather over the top of the mold and it touches the other breather for air transfer/movement.
What am i doing wrong?
