I got a couple of questions for the infusion experts here! Basically the problem is that I seem to be getting what appear to be air bubbles and resin build up in certain areas of my part that I am making. I am sparying the mold with clear gel coat mixed about 10% with Duratec high gloss additive. I set-up the infusion, pull vacuum and I get about 29" of vacuum and it will hold very well with 1-2" loss over 20 minutes. The resin I am using is very low viscosity (125cps) PER.
Here is what I get when I pull it from the mold.
The thing circled in red is a pit in the gel coat about 1/16" deep and the blue circle is excessive resin build up. The bag seems to sit flat in the mold before I introduce the resin. I have a few theories about my problems which are #1. Moisture in the gel coat. #2. My vacuum pump does no pull enough CFM to keep the bag flat after I let the resin in. I built a homemade vacuum pump with a fridge compressor. I am not sure if it is possible to have full vacuum but not enough CFM??? #3. Spraying the gel coat to thin.
I have had them come out of the mold with very little resin build up and no bubbles or pits and then other times it will look like the pic, but nothiong in my technique changes. This one has me stumped. Let me know what you guys think.
