I just ordered some of this stuff, but I want to make sure my thoughts are correct on its use…
http://www.aircraftspruce.com/catalog/cmpages/aeropoxylight.php
I’m going to lay in some Nomex honeycomb on a cured piece of carbon (bottom of a ski board), and I’d like to fill in some gaps around the edges and fill in some of the bottom curves of the ski. I’m thinking that having a flatter surface to bond the Nomex honeycomb, the better…the AeroPoxy Filler will allow me to smooth the bottom out and fill in around the edges.
Now, I would like to do this DURING the layup. Is it smart to use the filler on the bottom, spread some resin around, then lay in the honeycomb? Then fill in some gaps around the sides of the honeycomb with the filler, then lay over and wetout the next 5 plys of Uni-carbon? Then bag and cure the AeroPoxy Filler, honeycomb, and carbon all together?
Thanks.
Also, I’ll add a picture so you can get an understanding of what I mean about filling in around the edges of the honeycomb. Also, the bottom of the board shell is curved…and I want to use the filler to help smooth it out. This picture is of the bottom shell of the board and the honeycomb just laying in there – I have not cleaned up the flange yet, because it’s all going back in the mold…
Just make sure the nomex is clean and oil free.
