I want to preface with I am still learning A LOT. But I’d like to give ya’ll a good picture trail. I used foam from avtcomposites and used Aeropoxy 2032 for the first time. Also my first time using a vacuum bag.
Here is my mirror I didn’t like in my room. You can see in background my crude box, supports 160f.
Pulled 2x 10min vac’s. Worked out pretty well, but on one occasion I used too much epoxy and it started kicking before I got through all the layup and I had to mix up some new stuff. Very high stress, when your using the last of your CF.
Please note that I can fit all the rest of the plates I needed. Yet I messed up and didn’t fit them all due to thinking I could remember the order. Doh!
Lot of wasted CF, and I won’t be doing such a large piece Solo I don’t think. Time to train my room mate, or my girlfriend. Undecided as only one will cost me money ha.
Cut these out using the higher end dremel from home depot and cut off wheels. Went great, but I’m thinking different discs would have sped this up. I had a 3m 6001 mask I wore the whole time.
Piece of wood and screws let me paint my parts for first time using a HVLP. Went pretty good, but NEVER under light parts you paint. Made for a lot of runs, which takes a ALOT of time to fix.
Sent this to friend Josh and he wonders why I beveled the edge. Another lesson is be clear on plan with client.
Selfie, drove down 3 hours to deliver and watch over install. I made it back home around 7am and moved to a new house the next two days. #goodtobeyoung
