Hello and thanks in advance for those who reply.
I’m working on a very small project for really kicks and they’re bucket seats. The materials I’m using are the MTI hose and also the duratec sunshield IMC.
Details are that it’s a single piece seat with mounting hardware on the side, basically 2 bolts on each side with 4 total securing the seat to the seat rail.
This is a mold that needs to be double bagged as well so I’ll be envelope bagging everything.
The issue I’m coming across is that the mold is already done. I made it with just slight indentations where the bolt mounting holes are on the side. I originally thought it would be fine to just use some some epoxy adhesive, then put carbon around the base of the “weld nut”.
If you are unsure about a weld nut here’s a link to what they look like.
http://www.mcmaster.com/#weld-nuts/=y2x3lo
Let’s say above is option 1, drill the hole and then add the mounting hardware later.
Option 2 would be this:
Drill holes in the mold all the way threw, since it’s being envelope bagged it’s fine.
Take a bolt that the weld nut will attach too and put the base of the weld nut in between inner layers of the carbon. The bolt will secure and hold the weld nut from moving since it will be on the outside of the mold and the weld nut will be on the inside of the mold.
If anyone has any suggestions or tips please let me know. I’ll probably use plastic bolts and coat with release agent for easier release than metal as well.
