I am trying to figure out the best way to apply fibreglass and gelcoat to a sandwiched foam panel which has a grp and gelcoat finish both sides,
Currently I have cut the panel to size and have foam exposed all around. I wondered if anyone has a technique for finishing the edge please? The gelcoat and grp skin is only 2.5mm thick and my concern is getting a reliable bond between the existing skins and the edge. I am using polyester resin by the way.
I was going to remove around 2mm of foam around the edge and use fibreglass filler originally, this still leaves a problem of achieving a reliable bond between the already cast skins which may lead to splits forming along the edges?
Has anyone successfully achieved this please? I seem to be going around in circles thinking about it!
