The only things I have tried so far are the half face masks with the replaceable pink filters and some disposable dust masks early on.
My next purchase is going to be either a full face mask or full hood.
Infused, I haven’t heard of the air bench but I will check it out.
With the 3m half face I started noticing black cf particles when went to blow my nose. That means the seal isn’t good enough for daily cf cutting or sanding etc.
It could just be the shape of my face and it not being a good fit but I doubt it.
The risk of an occasional failure is probably no big deal if you do an occasional project once or twice a year. I not a good risk go take every day though.
My understanding is that the problem is that any cf dust that you inhale does not come out and that there is nothing any doctor can do about it. It is a similar problem to asbestos. I.e. The shape of the particles causes them to get embedded in you lung tissue like fish hooks and nothing good happens after that.
Reading about the potential (and likely) health problems of cf dust gave me nightmares. I’m not one to raise panic unnecessarily but I feel that this issue warrants a degree overkill on the safety gear.
I would like to find something reliable I can afford but if I can’t, I need to find a way to buy the versaflo that F1Rob recommend. I am trying to keep in mind that his suggestion came after he has damaged his lungs and it sounds like he wishes he could go back and advise himself to be more careful and buy the right respirator before losing his lung capacity…
