Hi,
Here’s my process - I’m reinforcing cured prepreg CF/epoxy parts with additional layers of prepreg. The cured part is sanded and cleaned, or sometimes has a peel ply surface, and then the subsequent layers are laid up, compressed and cured.
So I’m relying on whatever epoxy flows out of the additional layers to create the bond to the cured part surface.
It works OK, but I’ve been hearing about adhesion promoters, and wondering if there is anything to be done to improve the bond strength.
So my question is - what’s an adhesion promoter, should I be using one, and what exactly should I be looking for?
