I hope this is the right place. I have received my ABS kick panels and did some experminting on the sample piece and it works. What I did was sand an area real good with 320 and and sprayed both the ABS and the material,vinel I think, with the Orange 3M and let it almost dry then sprayed again with a light coat and pressed them together while rubbing them. The reason I did this was to work the 3M into all the little rough areas of the material and the textured areas of the ABS I tested it 24 hours later and it is stuck.
Does anybody else out there would like to share how they did it.
