What products to you guys recommend for the sanding and polishing process after the epoxy is cured?
I’ve watched manufacturers use a wet sanding technique with sandpaper and various compounds.
I see 3M has an extensive product line-up. What do you recommend?
What grit sandpaper(s) should I order and what polishing compounds? I’m going to start out doing everything by hand so I was planning to get wet/dry sandpaper and 3M polishing compounds.
I’ve used 3M Finnese-IT on my car…but that’s about it.
Thanks!
