If you ever planned on using colored fiberglass-carbon hybrid… I wouldn’t suggest making an actuall part until you have done some testing with the material.
I talked with a vendor and from experience I can say that the colored fiberglass hybrid we had on hand in various colors sucked. Polyester and vinylester resin will not bond to it so the laminate just peels apart after the resin is cured. Epoxy resin would probably work better, but it’s best to run a test part so you can pick, peel, and generally abuse the part to see how it holds up; before trying to make the final part.
