Thank you for your kind comments.
Sduffass:-
I use a mixture of either 200gsm or 375gsm depending on each part I make, also different amounts in areas which need more strength, mounting points ect.
A typical side fairing I would use 3 x 200gsm, plus 1 x carbon/Kevlar just on the mounting points.
On a seat unit or something similar, if required I use Lantor Corematt, or Corecell,
http://www.ecfibreglasssupplies.co.uk/c-455-lantor-coremat.aspx
http://www.marineware.com/index.php?option=com_content&view=category&id=52:structuralcores&Itemid=69&layout=default
However I am no expert, as others on here are far more experienced than myself.
“a double”:-
The Vee seam is ok but not 100% perfect as I haven’t lined up the twill spot-on.
I lay-up one piece with a “dead cut” in the mold on a joint line in the mold, or on a feature line on the part, then the second part is “overlapped” on the back by about 20mm so its not a “Butt joint” however you can’t see the joint line when doing this so its always a bit of a guess work as I never know how good its going to be until I remove it from the mold, sorry but it’s the only way I have managed to get a half good looking seem.
Hence why the twill doesn’t line up perfect, but it will do for me until I try pre-preg in the future.
To seal the mold, rather than try to seal all the joints I cheat & I just put the whole mold in a large vacuum bag, and on the joints I put tape over the nuts & bolts to prevent them from bursting the Vac-bag.
Banned:-
I just take my time & thoroughly wet out the carbon, & I use Gurit Ampreg 21
http://www.gurit.com/files/documents/ampreg-21v7pdf.pdf
This allows me from 2 – 3 hours to latest vac on, depending on the temp, so it’s not a mad rush, I also wet out an off-cut of carbon and wet this out when I start as this helps me to gauge the latest time I need to put the vacuum on.
Sorry never tried infusion or pre-preg so couldn’t comment, but will try both in the future.
Last of all a great deal of credit must go to my painter who gets a great finish with the Clear coat lacquer, its straight from the gun, no flatting and buffing, & it still looks wet, mind you he isn’t cheap.
Hope this helps.
Best regards.
