#77 Spray Adhesive and Expoy Resin
Can I use #77 Spray Adhesive and Expoy Resin to insure the items I overlaid/wrap don’t peel, or just use expoy resin.
I know about drilling holes so the resin goes through and act like revits.
it will only hold it down till you start adding epoxy, then it really loses all it’s properties
I have had success using Super 77 to hold the material initially in place while I put down the initial wet out with resin. An alternative is to put down the epoxy resin first, let it tack up, then put down the fabric. Build resin layers from there.
I use it at well but just as you start putting resin on it, it breaks down
