advantages… a few off the top of my head (in my opinion)
easier to work with pre preg for difficult layups than dry layup
Easier to cut and kit on CNC fabric cutter with pre preg (allows for very intricate and detailed kits)
Better control of resin content in a part
Can make parts from unidirectional, thus a much higher fiber volume
Less wasted resin
Ability to use high temp resins
cleaner and easier to work with than dry fabrics
Potential for different curing methods including bladder molding, thermo expansion molds, RTM, press parts, oven cure, autoclave cure, etc.
Being a temperature cure, potential for parts that don’t need post cure.
price… Can be good if purchased in quantities.
No ‘setup’ of the feed system you’d use in VARTM
More even laminate thickness
Ability to use automated layup ATL
wide selections in resin systems
These are just off the top of my head… Each process has it’s advantages and disadvantages. (which listed none here) If I could, I would only use prepreg for personal projects. I would obviously use whatever process was best for the part, price, experience level, or other requirements of the job. Since working with prepreg, I really appreciate the versatility in what geometry can be used and the ease of layup on complex shapes. Having to store in a freezer and use the oven, are however a pain… especially when working on projects at home.
