I searched the forum and couldn’t find anything on a tube with the finish on the inside, I apologize if this has already been discussed…
I need to make some 6 1/2" (Doesn’t have to be exact as these are cosmetic), internal diameter tubes- between .030 and .060 in thickness, and varying lengths up to 3 feet.
I’m currently setup for vacuum infusion and would like to keep with that process if possible.
What has been your most productive way of doing this? I have wrapped PVC tubing, but it’s just too difficult to remove once cured. Plus, the finish on the outside of PVC is not exactly the best finish.
I’ve thought of dis-solvable mandrels, but I have zero experience with those products.
Thanks in advance for any and all feedback.
