5HS Prepreg
I’m looking at getting some prepreg and am considering picking up a 5HS weave in 300gsm/9oz, as opposed to getting a regular plain weave or 2x2 twill. This is partially because the company that I’m ordering it from only has 5hs in regular stock for a 300gsm weight whereas they would have to order the dry fabric if I asked for it in 2x2.
So my question is - is there any reason I wouldn’t want to use 5HS in a prepreg application? It would actually be more drappable and have less crimp, and this more stiffness, than a regular 2x2, and since it’s a prepreg, it shouldn’t have any issues with loose fibers falling apart and just being a general pain to work with as a dry 5HS fabric would be. I have just never seen a 5HS used in a prepreg form before, and given benefits I listed above I’m just a bit nervous because I keep on thinking that I’m overlooking something that might detract from its usefulness. Anyone have any ideas? Why don’t you see 5hs used more frequently in prepregs?
The 5hs should be good to work with especially with curved surfaces. It us of the strongest wooven type and i dont see any reason not to use it.
5HS isnt a balanced fabric, so you need to flip the fabric to make it symmetrical and balanced.
That is right .
If you plan to use one layer then you got a problem.
I was under the impression that a 5HS is actually symmetrical, and the bias is just dependent on whether you are looking at the a side or the b side of the fabric? Is that not true, and it is biased on both sides with 4 tows running in one direction and 1 tow perpendicular?
The 0 degree is mostly on one side anx the 90 almost completely on the other (except where they cross). It’s more like a ply of 0 and 90 uni stacked together and “self stitched”.
A simple balanced layup would be A-side up, and then B-side up.
Any harness fabric, especially the higher number harness, is going to be less damage tollerant. Any hole (drilled or punctured) is more likely to fray or crack with a harness fabric than a plain weave. Still, it’s a good compromise between a woven and uni.
