hi
I recently tried to infuse some 4 mm thick all carbon parts. I did a small flat panel as a test about 150x 150 mm. Everything went well and the part came out flawless. Next I had to do a 300x400 mm panel. I started the infusion and it seemed all the part reached wet out but when it came out of the vacuum the epoxy did not reach some of the bottom layers from about half way of the panel. I also did some parts in a mold with similar results:mad:. After this epic fail I hit the forums again and found 3 possible problems with my process:
- My epoxy is not good for the infusion. although I got a low viscosity resin it’s work time is only 20 minutes. The infusion for the panel took probably 30 min or more.
- The thickness of my composite has to be 4 mm. Someone suggested in a thread that carbon can be infused only up to 2-3 mm. This can’t be true…I’ve seen thicker carbon panels that were infused.
- Also read the mesh could be a problem…there are faster an slower mashes. I went cheap and used mosquito mash but bought peel ply. However when I let the resin in, the infusion line seemed to go quite fast for the first quarter of the panel.
I added some pictures to showcase the process and the results. Hope I get a good lesson from you guys and find out what i have done wrong. Also if someone from Europe can suggest where to get some good resin for the job it will be welcomed. Thanks!
