Doesn’t work with epoxy infusion. The results may have been different if using VER or PER. Either that or i may have used a little too much. I was careful about how much i sprayed onto the mold, but the epoxy resin did not disolve the spray adhesive. I’ll get 3M 77 next.
The epoxy I belive is fully cured on the demolded part. Do you think it’s safe to use acetone to wipe off the remaining spray glue on the part? It’s infused carbon fiber and glass.
