I am searching for a good and relatively cheap service inside Europe for a project that needs a 3-axis foam cutting job to make the plugs. Could you recommend me someone? Thanks!
Hi, If its only 3-axis you’re after, there will loads and loads of machine shops in Greece that will be capable of cutting your plug; provided it isnt a crazy bed size your after. If it is a large bed size, then I suggest using a few dowels!
Indeed, 3 axis is not that hard.
3 suggestions:
Jib Design, Slovenia
Promorfo, Netherlands
Nedcam, Netherlands
Some surfboard manufacturers are using 3 axis CNC on their foam blanks.
