Hi all, first post here, I’ve been snooping around and while I feel there’s more I could learn from more research, I’d end up researching forever…
I am preparing to set up a prototyping operation so I can investigate product performance of various materials, angles, and resins. Product is a nearly round, straight tube, about 0.040" thick wall. I’ll make prototypes at 3’ long. I need to control OD and certain axial features hence the clamshell mold.
Mold will be made of 7075-T651 Aluminum. It will have heaters and a ramp/soak controller. Materials will be epoxy prepregged sleeves of CF, aramid, and fiberglass and hybrids.
Bladder will be a simple 2 mil poly sleeve. I intend to seal the end with my bag sealer. I’m working on way to seal the supply end so I can vent trapped air. Bladder may stay in the part when done, it’s not critical.
Questions and concerns:
Should I make the mold set so it’s open at each end or closed at one end? There is no need for the product to have a finished closed end. Just thinking about sealing the ‘far’ end.
Shrinkage: I can’t find out much about epoxy resin shrinkage except ‘not much.’ Right now I have it drawn with a 1.5% shrinkage factor…sound OK?
Trapped air…really worrying me. Are vent holes necessary? Here’s my idea:
a. pre-assemble my sleeve/bladder partly over a long bottle brush,
b. wet it with resin before I lay it in the mold,
c. loosely clamp the mold,
d. gently pull bottle brush towards the open end, to burp out any trapped air and press the sleeve tighter to the mold,
e. tighten mold, pressurize, and begin heat cycle.
Thoughts on use of bleeder material between bladder and sleeve if the bladder is to remain in the part?
thoughts on whether vacuum could be helpful here, or would it just add complexity?
Looking back, this is long…I thank you in advance for your help,
Haywire
