Alright guys, so I had two failed parts that failed at the same time. We have not had a failure like this in a long time. So I’ll first explain the laminate, then the problem.
Two molds roughly 11" wide by 38" long with a 2" raised lip all around. They are door sills. I laid in two layers of 6oz carbon fiber, one layer of 1/8" inch core matting, and one more layer of 6oz carbon fiber. One layer of nylon release peel ply was added and green flow mesh.
On the first mold I had a vacuum line attached on the right side of the wider end of the mold. Off the left side of that same mold there was a tube going to the second mold. On the other sides of the molds were 3/8th inch infusion lines.
I infused at full vac and then noticed there were many pin holes in the bags. Not sure how they got there, but I plugged them all up. Or so I believe…
The problem I had was that the resin just would not flow. I’ve made the same parts many times with the same resin and never had problems. The resin just would not flow. It saturated, but didn’t flow.
My guess is that there were still a few pin holes in the bag and that somehow didnt allow the resin to be vacuumed into the mold? Could that be a proper assumption?
