I’m liking the potting idea + using a metal guide for the bolt.
I thought about foam core, but i am just a little afraid the thickness won’t come out exact to what i need using this core material. I always wanted to try aluminum honeycomb too. But in the end i want what works right.
how about closed cell polyurethane foam sheet? Does anyone know where i can buy it cut to 1/4" sheet thickness?
Would it be wise to do the same with the PU foam: drill out a small area where the bolt will go thru and fill it with potting resin, then drill the bolt hole?
The final part will be a functional side skirt for a race car.
