Something to think about since this is a composites forum after all.
A lot of high-precision machines are being made with composite construction now. There has been much discussion on cnczone but not a ton of real progress there for a DIY solution.it seems they are more focused on the “perfect” formulation rather than just diving in.
Basically, the composite material is resin mixed with an aggregate in a mold with reinforcement, mounting plates, threaded inserts, etc. cast in as needed for the design. Most are using epoxy and things like sand and various size rocks, pebbles, etc. as aggregate.
Most focus seems to be on getting all of the air bubbles out when molding the components
The great thing about this, a person could build a usable sized production capable machine without need for expensive cast iron foundry work. The “epoxycrete” castings have very high mass,stiffness, and great vibration damping.
I did see pics of a of a small machine a guy from Germany (I believe) was building. Wish I could see more since it was well executed. But the pic came from a foreign language board and I nevr saw a link to it.
